A Catholic Dictionary
Mikeee
A CATHOLIC DICTIONARY
AMEN:
The only part of a prayer that everyone knows.
BULLETIN:
1. Parish information, read only during the homily.
2. Catholic air conditioning.
3. Your receipt for attending Mass.
CHOIR:
A group of people whose singing allows the rest of the congregation to lip-sync.
HOLY WATER:
A liquid whose chemical formula is H2OLY.
HYMN:
A song of praise, usually sung in a key three octaves higher than that of the congregation's range.
RECESSIONAL HYMN:
The last song at Mass, often sung a little more quietly, since most of the people have already left.
INCENSE:
Holy Smoke!
JESUITS:
An order of priests known for their ability to found colleges with good basketball teams.
JONAH:
The original "Jaws" story.
JUSTICE:
When kids have kids of their own.
KYRIE ELEISON:
The only Greek words that most Catholics can recognize besides gyros and baklava.
MAGI:
The most famous trio to attend a baby shower.
MANGER:
1. Where Mary gave birth to Jesus because Joseph wasn't covered by an HMO.
2. The Bible's way of showing us that holiday travel has always been rough.
PEW: A medieval torture device still found in Catholic Churches.
PROCESSION:
The ceremonial formation at the beginning of Mass, consisting of altar servers, the celebrant and late parishioners looking for seats.
RECESSIONAL:
The ceremonial procession at the conclusion of Mass - Led by parishioners trying to beat the crowd to the parking lot.
RELICS:
People who have been going to Mass for so long, they actually know when to sit, kneel and stand.
TEN COMMANDMENTS:
The most important Top Ten list not given by David Letterman.
USHERS:
The only people in the parish who don't know the seating capacity of a pew.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
