Vin Check Please
Just purchased 2003 Yukon and needing assistance from those more informed than I. Wondering if can install heated power seats (passenger/driver side) as just purchased a set via Ebay. Also woull love to upgrade to a navigation system similar to what's in Denali from that same year. Any assistance would be dearly appreciated as this is first GMC ever owned.
VIN 1GKEK13Z23R100864
GM Vehicle Inquiry System
Summary
VIN : 1GKEK13Z23R100864
VEHICLE INFORMATION
Merchandising Model : TK15706 -2003 YUKON - 4WD
Warranty Start Date : 10/16/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : LAWRENCE MARSHALL BUICK-PONTIAC-GMC
8811 LAKES @ I-610 DRIVE
HOUSTON , TX 77054-2524
(713) 838-7000
Selling Source : 48 - GMC TRUCK
Site Code : 08214
Business Associate Code : 189802
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes
OnStar Status Inactive
Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes
XM Radio ID EL1C00MB
XM Status Inactive
Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/16/2002 258 miles 10/16/2005 36258 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/16/2002 258 miles 10/16/2008 100258 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 10/16/2002 258 miles 10/16/2010 80258 miles
36/36000 FEDERAL EMISSION 10/16/2002 258 miles 10/16/2005 36258 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/26/2005 770433 # D4440 - COMPRESSOR ASSEMBLY - REPLACE 32930 miles
08/26/2005 770433 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE 32930 miles
08/26/2005 770433 # N0110 - BATTERY - ONE - REPLACE 32930 miles
08/06/2005 243300 # Z2081 - ROADSIDE SERVICE (LOCKOUT) 32000 miles
06/01/2004 774896 # N2116 - SWITCH - SWITCH MODULE, FRONT DOOR - RIGHT - REPLACE 19322 miles
06/01/2004 774896 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 19322 miles
07/01/2003 699660 # L1020 - CAP, FUEL TANK - REPLACE 10200 miles
04/07/2003 681696 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 6277 miles
03/17/2003 677849 # N8521 - TRANSFER CASE SHIFT CONTROL MODULE REPROGRAMMING WITH SPS 5707 miles
02/20/2003 674100 # C3358 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 4443 miles
11/01/2002 656703 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST 765 miles
07/23/2002 A00864 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 08/26/2005 Repair Order Number : 770433 Odometer Reading : 32930 miles
Serviced By : FRANK KENT PONTIAC-GMC LTD
PO BOX 123049
FORT WORTH, TX 76121-3049
(817) 696-4000 Selling Source : 48 - GMC TRUCK
Site Code : 47448
Business Associate Code : 116547
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
09/02/2005 618 01 # D4440 - COMPRESSOR ASSEMBLY - REPLACE 15100338 Y
09/02/2005 618 02 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE 88982875 - LINING KI N
09/02/2005 618 03 # N0110 - BATTERY - ONE - REPLACE 19001632 - BATTERY N
Repair Order Date : 08/06/2005 Repair Order Number : 243300 Odometer Reading : 32000 miles
Serviced By : GM ROADSIDE ASSISTANCE/CCAS
ONE CABOT RD
MEDFORD, MA 02155-5117
Selling Source : 13 - CHEVROLET
Site Code : 34415
Business Associate Code : 207453
08/12/2005 612 01 # Z2081 - ROADSIDE SERVICE (LOCKOUT) N/A N
Repair Order Date : 06/01/2004 Repair Order Number : 774896 Odometer Reading : 19322 miles
Serviced By : LAWRENCE MARSHALL BUICK-PONTIAC-GMC
HOUSTON, TX 77054-2524
(713) 838-7000 Selling Source : 48 - GMC TRUCK
Site Code : 08214
06/11/2004 490 01 # N2116 - SWITCH - SWITCH MODULE, FRONT DOOR - RIGHT - REPLACE 15202857 - SWITCH N
06/11/2004 490 02 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE N/A N
Repair Order Date : 07/01/2003 Repair Order Number : 699660 Odometer Reading : 10200 miles
Site Code : 08214
07/11/2003 394 01 # L1020 - CAP, FUEL TANK - REPLACE 15763227 - CAP N
Repair Order Date : 04/07/2003 Repair Order Number : 681696 Odometer Reading : 6277 miles
Site Code : 08214
04/11/2003 368 01 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 26098419 - LUBE KIT N
Repair Order Date : 03/17/2003 Repair Order Number : 677849 Odometer Reading : 5707 miles
Site Code : 08214
03/25/2003 363 01 # N8521 - TRANSFER CASE SHIFT CONTROL MODULE REPROGRAMMING WITH SPS N/A N
Repair Order Date : 02/20/2003 Repair Order Number : 674100 Odometer Reading : 4443 miles
Site Code : 08214
02/28/2003 356 01 # C3358 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE N/A N
Repair Order Date : 11/01/2002 Repair Order Number : 656703 Odometer Reading : 765 miles
Site Code : 08214
11/15/2002 326 01 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST N/A N
Repair Order Date : 07/23/2002 Repair Order Number : A00864 Odometer Reading : 0 miles
Site Code : 08214
07/26/2002 294 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
VEHICLE BUILD
Gross Vehicle Weight Rating : 3133 kg (6908 lb)
Order Number : FHWXFH
Build Date : 07/23/2002
Build Plant : 13R06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - POWER DRIVER SEAT ADJUSTER
AJ1 - DEEP TINTED GLASS
AJ7 - DRIVER/PASS FRT & SIDE AIR BAGS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AL4 - SECOND ROW CAPTAIN'S CHAIRS
ARL - PLANT CODE-ARLINGTON, TX
AS3 - THIRD ROW 50/50 SPLIT BENCH SEAT
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AXP - MPV VIN IDENTIFICATION
A31 - POWER WINDOWS
A95 - 6-WAY POWER DRIVER BUCKET SEATS
BVE - ASSIST STEPS
B30 - COLORED - KEYED CARPETING
B58 - FRT & CTR CARPETED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
CF5 - POWER SUNROOF HOMELINK
CJ2 - TRI ZONE AUTOMATIC AIR CONDITIONING
C25 - REAR WINDOW WASHER/WIPER
C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5H - GVW RATING - 6,900 LBS
C69 - REAR AIR CONDITIONING
DF5 - LT SENSITIVE INT R/V MIRROR W/OUTSIDE TEMP & COMPASS
DH2 - ILLUM LH & RH VISOR MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE
DL8 - HEATED POWER ADJ EXTERIOR MIRRORS
DT4 - SMOKER'S PACKAGE ***DEALER INSTALLED***
D07 - FLOOR SHIFT CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E52 - LIFTGATE W/LIFTGLASS
FE9 - FEDERAL/NY/VT EMISSIONS
FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ - RH
GT4 - REAR AXLE - 3.73 RATIO
G65 - LEVEL CONTROL MAN,SELF ADJUSTIN
G80 - LOCKING REAR DIFFERENTIAL
JC4 - HEAVY DUTY POWER DISC BRAKES
KG3 - ALTERNATOR 145 AMP
KNP - H.D. TRANSMISSION OIL COOLER
KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
L59 - VORTEC 5300 V8 BI-FUEL ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHL
NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE
NZZ - OFF ROAD - SKID PLATE
PDF - SOUND SYSTEM PLUS PACKAGE
PDQ - SECURITY PACKAGE
QC3 - POLISHED CAST ALUMINUM WHEELS
QMK - TIRE ALL P265/70R16-111S WOL
R6J - CUSTOMER DIALOGUE NETWORK
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS
T96 - FRONT FOG LAMPS
UC6 - AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPKR SYSTEM
UE1 - ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER
UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE SPEAKER SYSTEM
U2K - XM SATELLITE RADIO-100 CHANNELS OF COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA)
VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V22 - CHROME GRILLE SURROUND
V54 - ROOF MOUNTED LUGGAGE CARRIER
V73 - STATEMENT OF CERT. U.S.
V76 - RECOVERY HOOKS
XMK - TIRE FRONT P265/70R16-111S WOL
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR
YMK - TIRE REAR P265/70R16-111S WOL
ZMK - SPARE TIRE P265/70R16-111S WOL
ZM9 - HOMELINK UNIVERSAL TRANSMITTER
ZW7 - PREMIUM SMOOTH RIDE SUSPENSION
ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIP.
Z88 - GMC TRUCK NAMEPLATE
1SC - SLT DECOR ULTRASOFT FRONT LEATHER SEATING SURFACES ASSIST STEPS HIGH BACK BUCKET SEATS INCLUDES BOSE PREMIUM 9 SPEAKER SYSTEM REAR SEAT AUDIO CONTROLS
1SZ - OFF-ROAD PKG DISCOUNT
11U - PEWTER METALLIC
6XK - COMP FRT LH COMPUTER SEL SUSP
7XK - COMPONENT FRT RH COMP. SEL SUSP
92I - DARK PEWTER INTERIOR TRIM
922 - PEWTER LEATHER
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 10/16/2002
Delivery Type : 010 - RETAIL/INDIVIDUAL
Delivered Odometer : 258 miles
Delivering Dealer :
(713) 838-7000
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 08214
Honestly, yes you can upgrade the seats and nav unit, but it is not gonna be cheap
you are gonna need harnesses, antennas, relays, taps and correct mounting hardware. It is doable but is gonna require the better portion of a weekend once you have all the gear.
If u install the heated seats that would be sick, I have the heated seats on my V-Max and that is one awesome feature. On the navigation system I would rather go aftermarket than the stock GM one.
