I Need A Vin Lookup
I'm tying to figure out if the GM hood deflector, Blu 25U, is the same color as my truck. If it is the same color would blue look better than smoked??
VIN # 2GTEK13M671655623
Thats the correct color for your truck....
GM Vehicle Inquiry System
Vehicle Build
VIN 2GTEK13M671655623
VEHICLE BUILD
Merchandising Model : TK10543 -2007 SIERRA 1500 4WD CREW CAB SLT
Gross Vehicle Weight Rating : 3178 kg (7007 lb)
Order Number : KVPC4W
Build Date : 03/30/2007
Build Plant : 27143
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SEAT ADJ, DR 6-WAY POWER
AG2 - SEAT ADJ, FRT PASS 6-WAY PWR
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AN3 - FRONT BUCKETS W/POWER ADJUSTER
AP3 - REMOTE VEHICLE STARTER SYSTEM
ASF - HEAD CURTAIN SIDE-IMP AIR BAGS
AT8 - RR FACING CHILD RESTRAINT
AU3 - POWER DOOR LOCKS
A31 - PWR WINDOWS W/DR EXPRESS-DOWN
A68 - REAR 60/40 FOLDING BENCH SEAT
B30 - CARPETED FLR COVERING W/MATS
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR-KEYED FLOOR MATS
B85 - BODYSIDE MOLDINGS
CE1 - RAINSENSE WIPERS
CF5 - POWER SUNROOF
CJ2 - AUTO DUAL-ZONE AIR COND
C49 - REAR WINDOW ELECTRIC DEFOGGER
C5W - GVW RATING - 7,000 LBS
DF5 - AUTO-DIMMING INSIDE MIRROR W/ COMPASS & TEMPERATURE
DH6 - LIGHTED VISOR MIRRORS
DK8 - CONSOLE, OVERHEAD DELUXE
DL3 - POWER HEATED OUTSIDE MIRRORS W/DR AUTO-DIMMING, TURN SIGNAL, CURB TILT
D07 - FLOOR CONSOLE
E63 - WIDESIDE PICKUP BOX
FE9 - FEDERAL EMISSIONS
GT4 - REAR AXLE - 3.73 RATIO
G80 - H.D. RR AUTO LOCK DIFFERENTIAL
JF3 - DISC BRAKE
JF4 - POWER ADJUSTABLE PEDALS
JJG - FRT END SUBASSEMBLY
JL4 - STABILITRAK - STABILITY CONTROL
KG3 - 145 AMP ALTERNATOR
KNP - EXTERNAL TRANS OIL COOLER
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
LH6 - VORTEC 5.3L V8 GAS ALUM BLK ENG W/ACTIVE FUEL MGMT TECHNOLOGY
M30 - 4-SPEED AUTOMATIC TRANSMISSION
NP5 - LEATHER-WRAPPED STEERING WHEEL
NQH - AUTOTRAC TRANSFER CASE
NT8 - FEDERAL EMISSION SYSTEM
NZZ - SKID PLATE PACKAGE
NZ4 - 17" FULL-SIZE STEEL SPARE WHEEL
N88 - 17" BRIGHT ALUMINUM WHEELS
OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
PCY - SLE/SLT TRAILERING PKG: *HIGH CAPACITY AIR CLEANER *TRANSMISSION COOLING SYSTEM *H.D. RR AUTO LOCK DIFFERENTIAL *H.D. TRAILERING EQUIPMENT
PDD - CONVENIENCE PACKAGE: *ADJUSTABLE POWER PEDALS *REMOTE VEHICLE STARTER SYSTEM *REAR PARK ASSIST
PDL - OFF-ROAD PACKAGE: *OFF-ROAD SUSPENSION PACKAGE *SKID PLATE PACKAGE
QJP - 17" P265/70 ON/OFF ROAD, BW TIRES W/SPARE
R4Y - TIRE BRAND GOODYEAR
R6J - CUSTOMER DIALOG NETWORK
R6K
R6P - PREMIUM PAINT
R9L - SPRING WHOLESALE FLOORPLAN PLUS
R9N - LEATHER SEAT TRIM
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAB - ACTIVE FUEL MGMT ENGINE ID
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
SLT - 'LT' EQUIPMENT SALES PACKAGE
SSB - MODEL IDENTIFIER
TFE - SALES INCENTIVE-COMMITMENT PLUS
T74 - HEADLAMPS CONTROL AUTO, DELAY
T96 - FRONT FOG LAMPS
UD7 - REAR PARKING ASSIST
UE1 - 1 YR ONSTAR SAFE & SOUND (ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UG1 - UNIVERSAL HOME REMOTE
UJ6 - TIRE PRESSURE MONITOR SYSTEM
UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR AUDIO SYSTEM CONTROLS
UQA - BOSE PREMIUM SPEAKER SYSTEM
US9 - AM/FM STEREO W/MP3 COMPATIBLE 6-DISC IN-DASH CD PLAYER (REPLACES STD/OPT RADIO)
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA; 1ST 3 MONTHS INCL.
VB3 - CHROME REAR BUMPER
VG3 - BUMPER, FRONT CHROME
VK3 - FRONT LICENSE PLATE MOUNT
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V22 - CHROME SURROUND GRILLE
V73 - STATEMENT OF CERT. U.S.
V76 - FRONT TOW HOOKS
XA7 - HEATED WASHER FLUID SYSTEM
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD5 - FRONT SPRING - BASE EQUIPMENT
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR
ZK3 - PULL AHEAD IDENTIFIER
ZRS - SPARE TIRE
ZY1 - SOLID PAINT
Z71 - OFF-ROAD SUSPENSION PACKAGE
Z82 - H.D. TRAILERING EQUIPMENT
Z88 - GMC TRUCK NAMEPLATE
1SZ - OPTION PACKAGE SAVINGS
25U - DEEP BLUE METALLIC
33I - VERY DARK CASHMERE/LT CASHMERE INTERIOR TRIM
333 - LIGHT TAN LEATHER
4SA - SLT DECOR INCLUDES: *12-WAY POWER HEATED LEATHER BUCKET SEATS W/DRIVER MEMORY *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY *INSIDE AUTO-DIMMING MIRROR W/ COMPASS & TEMPERATURE *LEATHER-WRAPPED STEERING WHEEL *BOSE PREMIUM SPEAKER SYSTEM *STEERING WHEEL RADIO CONTROLS *REAR AUDIO SYSTEM CONTROLS *UNIVERSAL HOME REMOTE *POWER HEATED OUTSIDE MIRRORS W/DR AUTO-DIMMING, TURN SIGNAL & CURB TILT *HEATED WASHER FLUID SYSTEM *RAINSENSE WIPERS *CHROME SURROUND GRILLE *BODYSIDE MOLDINGS *AUTOTRAC TRANSFER CASE
6JW - SUSPENSION
7JW - SUSPENSION
© 1998-2005 General Motors Corporation. All Rights Reserved.
Ehh....I'd personally go with smoke,But Blue wouldn't look bad either :):sigh:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
