Nbs Accessories
As sales of NBS trucks specifically, full size trucks in general, retreat, will this effect the accessory avaialbility/product offerings/spectrum of available products ?
Just curious what ya'll think...
Of course it will, just as the end of the type writer did to the type writer ribbon market. Ok, may be not that extreme but less trucks being produced means a much smaller target audience & a hesitation to engineer new products as the pay back & profit may never come.
Also, look for pick up sales to go more comercial as retail consumers flea the market of gas guzlers.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
