Too Many Accesories
Guest Riggs
Guest Riggs
Alright well i have a GPS, Radar Detector, Ipod. using all 3 off my 12v plugs...
i dont really want to cut the plugs off and hard wire them because i switch them out from time to time....
what can i do here?
Guest Riggs
i also have a cable ran through the dash for my ipod to play through my radio (which i accidently cut today) ....
is there any way to tuck in uder the carpet and run it into the console??? i would like to hide these wires...
you could try to cut two small slits into the carpet and run a coat hanger under the carpet to fish the wires through. Not sure how the carpet is fastened down on that truck, but it might be worth a shot.
depending on what console you have there are a bunch of things you can do. If you have the same set up as i did on my 96 there is no carpet under the console so all you have to do is slide the wire under the carpet to the console drill a hole and poof there is your ipod connection
Guest Riggs
im thinking about getting a 1 into 4 splitter and hardwire that and then run all my cables to the space above the driver floor area and i would get all of my outlets back!!.
Just a thought for your Ipod. After rigging the jumper into my truck so I can play my mp3 player on the XM dial, I got a female head phone jack and a short wire with a male headphone plug on each end at Radio Shack. I then drilled a hole in one of the blank dash panels near my air bag switch, mounted the female adapter there and wired it into the jumper input wires behind the dash. Now, all I have to do when I play my mp3 player in the truck is plug the double-male wire into my mp3 player and plug the other end into the dash. The whole setup looks pretty slick and I don't have rogue wires dangling out of trim panels.
Guest Riggs
well my truck isnt equipped with a factory cd player and thsoe that werent came with that little storage tray...
i think im just going to run a wire into that ....
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
