Transmission Oil Cooler Lines
I just bought a 1994 GMC K1500 pick up. It is leaking transmission fluid from under the radiator. This could be the radiator or one of the tranny cooler lines. I'm thinking its one of the lines. Does anybody know the o.d. of the steel line so I can cut out the broken section and replace it with hose?
I`v never seen those leak from the metal part of the line, are you sure its not comming from the fitting in the rad? they always leak were they go from the tube to the flex hose.... my guess otherwise would be 5/8"? but it could be alittle bigger dunno....
I bought the truck for 100 bucks. It was sitting for 3 years and is very rusty. I was assuming that the one of the metal lines rotted out and is now leaking (all the fuel/brake lines were rotted). You could be right I have not looked under the truck yet.
Thanks, I will look under the truck tonight. Hopefully I can fix it with out replaceing the entire line. Its tough to put alot of money into a truck that only cost 100 bucks.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
