37" Tires On A 6" Lift Kithi
Hi i have a 06 Silverado 1500 Z71 with a CST 6-8" Lift Kit and right now im running
Toyo MT 295/70R17 (33.5x11.9). these tires had them before the lift but now i want to
go higher. So i want to know if i can run Toyo MT 37x13.5R17 or BF MT KM2 37x12.5R17?
and what gear ratio would you guys recomend me to install? right now i have the factory gears
3.73
At least 4.56, probably 4.88. 4.88 will bring the feel closer to the stock gears with stock tires.
Also be careful running 37s on 1/2 ton IFS, the largest you can go safely is 35s, so keep a very close eye on ball joints, tie rods, CVs, and wheel bearings. If there is any play in anything, replace it right away.
3.73
The site says it can run 35s. I would imagine you would have to have 4.56 or 4.88s for gears. I think the 4.56s will give you close to stock.
Thanks guys for your fast replays.
I know that cst and most brand suggest running 35" on 8" wide wheels. right now i have
pro Comp 9001 Series 17x9 and i dont have any rubbing issues not now and not before the lift.
I know that running bigger tires add stress to the suspension parts but my main concern is if
my engine and transmission can handle them? (Vortec V8 5.3L)
thanks
thanks
If you re-gear to at least 4.56 or 4.88, you should have no problems with the drivetrain.
if you are running 35's 4.10's will be more than sufficient. I have 4.10's with 35's on this truck and my last truck 2005 with a 5.3
I recommend going with BFG A/T KO's for an all terrain tire or if your wanting something more aggressive I have the Cooper Discoverer STT's and love em. they are similar to the Mickey Thompson MTZ's.
You can fit 37's on your truck if you add a body lift to go with your 6" lift but I'm not sure what gears to recommend.
Yup. The Mickey Ts are actually manufactured by Cooper. I've got the MTZs, and I love them. Good on road, even better off. :D
37's would be more then snug with only 6 inch lift. If you did a 2-3" body lift, it would clear them. For 37's I would recommend 4.88 gears. 4.56's with the 35's.
