99 K3500 Squeal/whine/rattle/whir
dogsrme
About a month ago, I started my 1999 K3500 7.4l at 6am (which I never do), and the belt started squealing like crazy. Restarted a couple times, and drove it anyway, thinking it was the dew (and it's not a morning person, like me) and would dry out. It just got louder and sounded like a high-pitched metal grinding noise. So I hit the belt with wd40 to see if it would shut it up. It did for a while, then came back....so I took it to the car wash (since there's alot of dust where I live and I usually go every week, but hadn't for 3 weeks, so figured maybe that's why it was acting up out of the blue). Then it's quiet for almost a month. Then I start it in the am again the other day, and it's back! I used belt dressing this time, which lasted one trip, then back to the wd40 and carwash trick to shut it up. Only this time it was worse after the car wash and sounded like a pop can was stuck in the fan (nothing's there). It's a scary screeching metal noise, but wd40 makes it purr like a kitten. Last time, there was no effect on my battery or temp gauges or steering, so I figured my water pump, alternator, and power steering pump were fine. Turning the ac off and on made no difference. This time, the battery gauge drops down when you first spray it (and in the car wash), which it's never done before--so I figured the belt is slipping from the belt dressing/wd40 combo. Now running the ac drags the battery down as well. Now what do I do? Do alternators make this noise when they are dying? Or ac compressors? Or????? Makes sense that something was going out in the first place, because why else would a quiet, perfectly good belt start shrieking out of the blue? But why did the alternator work fine last time and it stayed quiet for a month, and now it sounds like a train wreck and can't keep up? Is my belt going to snap off any minute? They say not to use wd40 cuz it dries out the bearings, well what bearings are these and is there a way to relube them? I live in CA, so any trip to a shop is $1000.00 just to say hello to them, much less "help!" So any ideas would be appreciated. If the power steering/water pump were going out, wouldn't I have steering/temp. problems? Also, my service engine soon light came on last week too--is that just emissions or could it be related to this? Thanks, please help me!
It's been a few days since this post went up and no one is answering so I'll shoot one at ya. You may have even moved on and found a fix. I know somone will argue with me here but putting any lubricant on the belt is a bad idea. It only masks the problem and creates more as you can see. The noise is a belt minorly slipping to a audible point. Adding WD40 or dressing or whatever just makes it slip fast enough to not be audible...for a while. Then that lube heats up and bakes into the pulleys and it is a bitch to get out. I have a little trick that usually works but not always. First I spray the crap out of the belt with something to clean up and dry out the belt and pulleys, usually brake cleaner. Then I get some valve grinding compound and coat as much of the belts and pulleys that I can get at. If your not familliar with it (nobody is who grinds valves anymore) most parts stores will carry it in a tube or tub. It kind of looks like antisieze with sand in it. That is not the what it is, do not go spreading antisieze on your belts, that's just what it looks like. It was a trick an old guy taught me for when they start squeeking, usually if the belt is not bad and none of the bearings are bad the culprit is a little surface rust on the pulleys. The valve grinding compound cleans that up without adversly reacting with the rubber. In that case we only put a little on both sides of the belt. I find it works for cleaning the dressing crap out of the pulleys.
Any way spread that crap all around on the belt and pulleys then start the engine and let it run for a bit. Rev the engine and wear that crap in. Depending on how everything looks I might do it again. After that remove the belt and run a rag over all the pulleys to remove any excess compound and install a NEW belt. The old one is junk don't even bother trying to save it.
If this doesn't work and it sometimes does not I take the time to access all of the pulleys and clean them off with a wire brush then install a new belt. This is the right way to do it and you may just want to go this route but I find the other way works alot of the time.
Yep any bearing in the pulley system will make this noise when dying but if it goes away when you spray the belt it isn't a bearing, they are all sealed.
Might be related might not, I would wait to address the light till you are mechanically sound.
Good luck, let us know what happens.
I was told to never put any kind of dressing on a serp belt. It could cause it to slip off of the idler pully's. I had an annoying sqeak a couple years back that would just not go away. I took the old belt off and cleaned the pully's real good, and then installed a Gatorback belt. The noise went away, and I haven't heard it since.
You know, my dad had a squeal at start up on his '94, and one day it just wouldn't go away. The volt gage also didn't want to come up. Finally the squeal stopped and everything came up just fine. We got home and I had him re-start the truck, and I'll be damned if the belt wasn't moving with the crank pulley. Turns out when he'd had it serviced the last time he had issues returning from a hunting trip out west (pulley locked up and fell off - never made a sound until the clunk), the idiots at the shop completely ignored the belt routing diagram RIGHT THERE ON THE FAN SHROUD and routed it wrong so that only 5-10* of belt were touching the crank pulley. Got him the right belt (they'd gotten a longer one because the right one 'wouldn't fit') and he hasn't had a problem since.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
