4l80e Trouble?
I have a 2006 GMC Sierra 2500HD 4x4 6.0L with a 4L80E tranny, and it has about 50000km's on it. I have noticed recently that sometimes I drop the truck in drive and you hear it settle into gear and then as soon as a touch the throttle nothing happens and the rpms climb to about 1500 and then it kinda jumps and goes forward almost like the tranny is slipping? Has anybody else had this problem as well. I still have a factory warranty so im wondering if i need a tranny, and how i would make it do it all the time because right now the problem only occurs every week if that. Thanks.
Sounds like a check ball (acts like a check valve) is leaking oil bye. I bet once the engine is running for say 15-20 sec's and the tranny's pump is spinning, oil pressure builds and the tranny works normal?
My 2001 HD did the same thing at 49,000 miles. Over time, it will get worse. I ended up getting a new tranny.
The first start of the day truck will not move for a few seconds till pressure builds. If I don't use it for a day or two it takes longer to move. Once it moves all is fine. Been that way since 25000miles. (42000 now) I have just learned to let it idle for a few seconds before shifting. Doesn't seem to be getting any worst but if it is an easy fix I would do it.
Have you ever gotten it to a dealer to look at before the warrenty ran out? If the problem started at 25K I was thinking you might have gotten it look at. If so the problem maybe "grandfathered" and GM will fix the trans for you. Also you can always take it to a dealer and tell them whats up, and how long its been occuring and maybe they will help ou out. Not all dealers are bad, alot do what they can to help out. Good luck.
I talked to the dealer and they told me that unless it does it all the time, they will not be able to diagnose the problem, and mine will do it even after i have let it idle for a couple minutes in park and letting it site in d for about 15 seconds but it only does it every now and then, I only have 8000km's left on my warranty, so basically the dealer won't do jack cause they can't find the problem
Can you go to another Chevy or GMC dealer? Call ahead to the service manager and tell them whats up. If that fails call the areas GM service rep and tell them what is going on. Alot of times if you are forceful enough, or you get a cool dealer and service rep they will note the issue and basically extend your warranty. So if it does go bad later you are usually covered. I have heard or guys getting their engine/trans covered for up to 100,000 miles(this was prior to the 2007+ 100,000 coverage). I would basically call around and get a hold of a GM rep explain as best you can, being firm but polite and get them to fix it. To get a TRANS fixed is not cheap. Good luck!
Has a ticket actually been written or are you telling them the problem and they say they can't do jack and show you the door? There really isn't a whole lot to do unless we can duplicate the condition, that much is true. However if you have a hard failure after the warranty expires you will have a much easier time convincing GM of a goodwill repair or at least some help if the complaint was documented before the warranty is up.
That is my problem. The old can't duplicate the problem. I would need to leave the truck overnight ( a few nights would be better) so they can start it after sitting. Can't be without the truck. (works every day). It is a minor anoyance now I have learned to just let it idle before I attempt to drive.
I have taken in my truck, got it documented, but the service manager told me that if it goes after my warranty is off I get nothing for coverage even though i brought it in for that same problem. Anyways my other thought is to go to 140km 7 year warranty total plus through gm is another 3000 dollars, do you feel its worth it?
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
