New Tires And Exhaust
I've been really busy this summer so I havent had alot of time to be on the site, but I finally got the camera out so I could get you guys some updates of what I've changed on the truck. Unfortunately I didnt have time to wash it. :wtf:
So for now you guys will just have to put up with dirty pics. :lol:
Anyway I wore out my old Firestones, so I went and got some new Terra Grapplers.
Newtiresandexhaust008.jpg">
Newtiresandexhaust010.jpg">
After that I got a little tired of the glasspack that I put in place of my stock muffler last summer, so I got a custom dual exhaust from Jacks OK Tire. I had them put a Y pipe where the muffler was and had them run it straight out the back. I wanted something a little different so I kind of ripped off Darkainions idea... sorry they're just so cool.
Newtiresandexhaust002.jpg">
Newtiresandexhaust005-1.jpg">
Newtiresandexhaust001-1.jpg">
Newtiresandexhaust004.jpg">
Newtiresandexhaust006.jpg">
Newtiresandexhaust007-1.jpg">
Exhaust looks good. How does it sound?
Thanks man.
It's got a nice low rumble to it even with straight pipes, and its not obnoxiously loud.
I made a sound clip of it, but for some reason photobucket rejected it... I'll try again tomorrow.
Haha, Iowa Hancock, haha. :D Who do you owe it to? :wtf:
Give us a nice profile shot of that beast now!
Only you daddy would notice that :D , but to answer your question VMAX2007 :lol::D
I found some more pictures but that damn sound clip keeps getting rejected by photobucket! :) I might just have to take a different one and try that. Anyway here's some pics.
Newtiresandexhaust015.jpg">
100_0528-2.jpg">
100_0531-2.jpg">
Nice job. The exhaust looks pretty sweet! What size tires? 265s?
Yep 265's. I wanted 285's but they didnt have any on hand and I needed to get tires that day so I just went with the 265's.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
