Cargo Light
i noticed the only time my cargo lights come on is when i turn the dimmer nob to keeo the interior lights on and thats the only time arn't they supposed to turn on with the lights when i lock and unlock my doors?kinda pisses me off ....fords are like that
Yeah,Thats the way it works.
On the GMT800 trucks they had a separate switch where the cargo light would come on without the interior lights being on,I don't know why they changed it.
I thought I heard something a while ago where if you pulled some knob out slightly or something... Might be for something completely different though. :lol:
thats true
ill probably end up figureing out how to turn it on with out turning the intior lights on
thanks thou
I would think for safety reasons; so you are distracting someone behind you with the white light. That would be my guess.
Yeah its a safety reason, anybody ever follow someone down the road with one on? I have and it is distracting.
Are you kidding? The white lights are so weak the only thing distracting about them is how weak they are!
hahahaha I was going to try and replace mine with silverstars.
