Supercharger Question
I know this isn't a truck, but at least it's GM. :P
Besides, there are some pretty sharp motor guys here. My wife's '98 Regal's supercharger is starting to rattle. I've taken the supercharger belt off (only thing run by that belt) and driven it across town just to see how it runs without it, and it seems fine. Gutless, but fine. Anyway, we're not quite ready to fix the supercharger so I want to make sure that it's ok to drive around without the supercharger belt, especially if it seizes and we have to take the belt off to make it home.
Will it cause any problems to drive it without the supercharger?
