2005 Duramax Low Coolant Message
rokbrnc
I have a 2005 GMC 2500HD with the Duramax engine.
A couple of weeks ago the Low Coolant Level message came on. I looked around the engine compartment for leaks and found that a pinhole had been rubbed through the hose that leads from the overflow tank to the lower radiator hose; the hose had been rubbing against the radiator shroud. I replaced the hose assembly and refilled the cooling system which seemed fine for about 3 days, then the Low Coolant message was displayed again, I filled up the coolant tank again and burped the system with the bleeder screw on the thermostat housing.
Now it seems as if I am receiving the message and having to top off the system about every 200 miles. There is eveidence of coolant in the passenger side wheelwell and it seems as if the system is being over-pressurized since even when it is cold and not driven in a day or two, the system is still pressurized.
I have read some posts about a possible tear in the EGR cooler that could contribute to this, however I am skeptical since the pinhole in the hose was an obvious (physical) sign for the initial coolant loss.
Any ideas?
Any ideas?
Multiple leaks out of the question?
