02 Gmc Denali
h-d2
I bought this 02 denali awhile ago.Some times when i drive it the vehicle seems to rock side to side more than normal.I can hear the compressor run when i start it.It fills more in the front end when hitting a bump.Then sometimes it seems to drive pretty normal.What should i check out first?Is there any stabilzer shock up front that might be wore out?It has 115,000miles.Thanks for any input
Any clue if the factory shocks have ever been replaced? If not that's probably where I'd start...
Does the air shocks go bad even if they are not leaking any air?
Hi I have 2001 yukon denali i don't think ever was replaced the factory shocks ,Probably your's has the same problem now is wery bumpy my ride i can feel every little imperfection on the road  only question where can i find a replacement (dealer wery expen...)Part #15058601 code T7K THIS THE REAR SHOCKS Anybody has a clue where is a good deal on this replacements or which part would replace this? At Rockauto i can't match the code or the PN# Thanks
  • 1 month later...
www.arnottindustries.com has OEM autoride shocks for $199 each. I put them on in July.
Hi
Yes i seen they website but my only concern was they part nr: not even close to the oem part nr:!!
So you say those shocks works good? And you feel any difference?
Thanks Alvocado in advance!!
Hi
Part numbers frequently change. These are OEM GM Delphi shocks. You can always validate the part number with a local dealer to be sure. My ride improvement was noticeable after changing at 100k miles.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
