What Does It Need
Debadge it, (HAHA DADDY), then drop it 2, 4 put some 20's on it???
What r u trying to go for???? When you say meaty, iam thinking lift
You can't tell people to de-badge until you've removed those silly vinyl stickers. :banghead: So... STOP! :shakehead:
OHHH burn!!!!! Sorry buddy
You can't tell people to de-badge until you've removed those silly vinyl stickers. :D So... STOP! :shakehead:
:banghead:
i dont really need fog lights but i would like them i live in az so no fog really but i like those trucks that you see and your like wow thats tuff looking and when i see mine im like wow thats stock looking but i would like to "black out" my truck too
