Water Spots On Glass
Okay so I noticed I have this issue with dried water spots on my windows and can't get them off for the love of God. I tried mineral spirits/ acetone, but nothing happens. I've neglected applying rain X on the windows monthly, so in all likely hood it allowed the water to dry up. I always use the Mr Clean auto wash thing to wash my truck which filters out contaminates in water, and also have well water. It's the acid rain I blame for this, or the sun directly drieing up the water on the glass.
I haven't tried a razor blade with window cleaner, but don't think it will work. I once knew this detailer who had this special cleaner that if you apply it to a surface, it would easily remove tar, and other contaminates but can't remember what it was called.
Any suggestions what is a good product to clean these dried water spots off the glass?
I've used a 50/50 solution of water and vinegar. Dip a newspaper in it, and use some elbow grease...Got it off.
And lemme tell you how much work this is on Fred's rear windows. HOLY CRAP.
Try some Coca-Cola. That stuff cleans up a lot of junk. :lol:
Use Diet Coke instead...No sugar (that's what causes it to stain things).
Try some Coca-Cola. That stuff cleans up my junk. :D
Dude, try some soap and water or some Handi-Wipes or something. Coke is just a weird thing to do that with. :D
EDIT: I had to remove the comment where I called WeeMax an a$$hole. :lol::crackup:
Try some Coca-Cola. That stuff cleans up my of junk. :lol:
FAIL!!! :D
Try some Coca-Cola. That stuff cleans up my junk. :lol:
Dude, try some soap and water or some Handi-Wipes or something. Coke is just a weird thing to do that with. :lol:
EDIT: I had to fix my FAIL!!!. :thumbs::D
Wow Jeff, you finally came back from your tune forum......
I think they've hired him as as their entire marketing department. :thumbs:
As for the water spots, I've yet to run into one that some good soap and water wouldn't remove. Or even some good glass cleaner such as Stoners and a glass cleaning towel. Then when you're washing next time, get under some shade, and let the water sheet off of the vehicle. That alone helps reduce water spots a lot. Then dry quickly!
I'd also avoid the Rain-X stuff on the windshield. That stuff is very particular about how/when you apply it. My friend used to use it all the time and ended up with this thick film on the windows that was a pain to get off. Stoners did the trick though.
I'll think I'll try some cocaine on the glass, I have plenty of Keys to spare...
Wow, that shit sure brought back some bad memories. :dunno:
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
