Friction Modifier?
I'm changing out the axle seals and doing some rear brake work on my dad's truck.
It's a 2004 GMC Sierra 1500, 5.3 4x4 extended cab with a 6600lb GVW.
I am not using GM rear end lube. Does this truck require friction modifier?
Thanks in advance.
not sure why I bother to post because i am not sure about this, guess I am bored! But I think Mobil 1 75-90 gear lube is what is used.
That's not what I'm asking. I need to know if this rear end requires friction modifier.
The manual states to use GM 75w90 lube only.
I am not using GM lube. I am using Castrol 75w90.
I need to know if I need to add friction modifier or not because I don't know if the GM 75w90 lube comes pre-charged with it. The Castrol does not.
Hope that clears up my question.
This is what Amsoil recommends for your truck.
Differential, Front .....GL-5
All Temps......80W-90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Standard Differential, Front Full time 4WD.....GL-5[4]
All Temps......75W-90
Severe Gear 75W-90
Severe Gear 75W-110
Differential, Front Selectable 4WD.....GL-5
Severe Gear 75W-90
Standard Differential, Rear Others.....GL-5[4]
Severe Gear 75W-90
Severe Gear 75W-110
Differential, Rear W/ QS4 Axle.....GLS[5][6]
Severe Gear 75W-90
None of which have an additive.
Thank you, that's what I thought. I appreciate the quick answer, now if only the parts store can find the right axle seals I can get this thing off my hoist!
Does the truck have a rear locking differential? It's called the G80 in your RPO list, that would be the only reason you'd need the friction modifer.
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 228 Guests (See full list)
