Zaino Weekend
Hello all. I am spending the weekend preping the baby for the winter and all its hellish bringings it plans to rain upon my truck. I am starting saturday. I will provide to you pics of how badly swirled my black one year old beauty really is and also after pics along with my ending thoughts. So check back sunday to see the outcome. I have high hopes and am getting myself mentaly ready for the long process known to man as ZAINO!!!! :thumbs:
Chad
Sounds like fun, and I am serious. I wish I had more time on a weekend for detailing. Looking forward to seeing the before and after pics.
Thats what I am talking about!! This weekend is my winter prep/detail weekend as well. She is getting washed, clay barred, possible polish, then waxed. Also doing all of the interior. Should be a nice Sunday...
ME TOO!!! I just finished washing the truck about an hour ago and put it in the garage for tonight. And tomorrow morning it is getting the clay bar, mothers pre-cleaner, mothers polish, and to finish it off a coat or two of Meguiar's NXT tech wax. Tomorrow will be a long day!!!!
Zaino is one of the few products that will last you thru the winter.
If you want to use a wax, collonite is one of the few that will last beyond 4-6 weeks.
I didn't know that about ZAINO. I am not sure where to get that in Canada
http://www.zainostore.ca/
Alright guys. I washed the truck, clayed the truck, washed again with z7, zxf z5 polish, z6, zxf z5 polish, z6 zxf z5 polish, and z6. I must say it looks absolutely amazing! Tomorrow i am applying a couple coats of z2 to bring out more wetness and depth to the paint . This was the only weekend i was gonna have so im taking advantage of it. The paint is so slick too. ZAINO!!!!
Congrat and waiting for the pics...
Do you have any Z8? If you do, try some of that after you last coat and it will really set it off.
Alright I couldnt get any good before pictures but take it from me that my paint looked like ass for only being only one year old even though it parks outside year around. I had water spots acid marks from bird crap and all kinds of spider web effects that I didnt ask for while taking care of my baby. Anyway the Zaino process worked. Like i said i did 3 coats yesterday and 3 today since that is the max in a 24 hour period. My paint feels like glass and yeah i would say some waxes make your paint look wetter but they DONT last!!
Without further ado here it is:
Here is the hood. Look at the beautiful reflection!
Oh by the way. This is the only way i know to upload pics for you guys to see. I dont know how to insert the link that lets you login to see em. Sorry .
-CHAD
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
