Exhaust Outlet
I'm looking into a cat-back exhaust and have heard that exhaust outlets straight back are not recommended for towing. I would imagine for reasons that what ever your towing would get hot and dirty from the exhaust blowing staight onto your trailer. I was told it was more for people hauling livestock that you wouldn't want it straight back so they're not sucking up fumes. But I've seen people haul stuff all the time with straight back exhaust outlets. What do you guys think?
While the two scenarios you laid out sound reasonable, I think it may also have to do with straight-back exhausts are going to reflect more off of whatever you're towing, causing more resonance in the truck, making your exhaust seem louder.
If you angle them out the sides, the sound-waves aren't going "straight back" into whatever you're towing.. horse trailer, camper, boat, whatever... So, it won't reflect "straight back" into the truck. The result would likely be what seems like a quieter exhaust.
We have pulled sleds for years to upper Michigan with no problems. Watch that your tips do not stick out too far, as you may tend to brush up against them when they are toastie (and asking what's that burning smell...).
The following is from Flowmaster's website.
The Dangers of Carbon Monoxide
When an exhaust pipe exits directly to the rear of a vehicle, highly poisonous carbon monoxide gas may be drawn into the rear compartment. Even a slight opening or faulty gasket can allow significant exhaust fumes in. Check and replace seals regularly. This becomes even more dangerous when a side window is open which draws even more carbon monoxide gas inside. This applies also to vans, SUVs and station wagons. Rear exit exhaust systems should only be installed on pickups without camper shells or where camper shells are never used to carry people or animals. If you tow a trailer or carry passengers inside a camper shell in the back of your truck, you should select a single or dual side exit system. With rear exits you may find exhaust soot on the trailer you’re towing. And if you carry passengers in the back, you run the risk of carbon monoxide poisoning.
When an exhaust pipe exits directly to the rear of a vehicle, highly poisonous carbon monoxide gas may be drawn into the rear compartment. Even a slight opening or faulty gasket can allow significant exhaust fumes in. Check and replace seals regularly. This becomes even more dangerous when a side window is open which draws even more carbon monoxide gas inside. This applies also to vans, SUVs and station wagons. Rear exit exhaust systems should only be installed on pickups without camper shells or where camper shells are never used to carry people or animals. If you tow a trailer or carry passengers inside a camper shell in the back of your truck, you should select a single or dual side exit system. With rear exits you may find exhaust soot on the trailer you're towing. And if you carry passengers in the back, you run the risk of carbon monoxide poisoning.
That does sound very serious.
To answer your question if you're towing a trailer that will be occupied then it's a bad idea to have the exhaust straight out the back. Like the above article said, you have a greater chance of carbon monoxide getting into the trailer. You will never see a truck hauling livestock with an exhaust straight out the back because the fumes are bad on the animals. In addition, for those of us with diesels, straight-out exhausts don't exist and if they did you'd have the carbon monoxide danger, as well as the fact that the front of the trailer would be covered in soot. If you're only towing some open, such as a bike trailer or a boat, then straight-out won't be a problem.
That's the way I was thinking Cowboy, I'm mostly towing my John Deere LT110 riding mower. But if I ever had to tow a trailer for hayride at our church for instance I would hate for everyone to suck down the fumes. I wanted the Magnaflow straight back duals at Performance Products but I think I'll check around the local shops and see what I can find and have them bend the pipes at 45 or 90 degrees out the rear.
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
