05 2500 Trailer Harness?
xfiresk
can't seem to get power through the positive terminalon in trailer plug? any clue of what fuseit would be or maybe a relay, checked all fuses that have something to do with trailer and still no power or blown fuse that i can find
There is a j-case(30amp green, square shaped...called stud2, I think) fuse in the underhood fuse block you need to install...should have been taped to the harness if you had an oem harness.
