DamonG Posted October 28, 2008 Posted October 28, 2008 I decided against the aftermarket nav/dvd set up. I'll put away and buy a factory take out one day. I did however buy the new switch for the fuel and trip calculator button on the steering wheel since it does not light up anymore. How do you remove the airbag? I read where there is two holes to place a screwdriver in but I dont see them on the back of the wheel. I do see two holes on each side of the back part of the wheel. Is that where you place the screwdriver? Will it just pop off or do I have to pull it off? I know to disconnect the battery and let it sit for 20 minutes before performing this task. I already messed up and pulled the switch out of the wheel and while doing that I pulled the four wires to the switch out of the harness so I have to fix that. There is not enough slack in that wire. Thanks for looking and for any help you have. Damon.
DamonG Posted October 29, 2008 Author Posted October 29, 2008 Got it and the switch. The holes were on the rear side of the wheel on both side. I used my small screwdriver to pop it. Those switches on the wheel for the audio and computer controls are a pain. Their is not enough slack to get the switch out to unplug it. I ended up pulling the wires out of the harness head on the back of the switch. I had to splice on some wire to get enough to push the head of the plug into the hole and plug in the switch and re-install in the wheel. Not any fun.
