Cargo Light
Has anyone figured out how to wire the cargo light on a GMT900 to a seperate switch so it can be turned on without the interior lights being on? I can't stand that. The GMT800's weren't like that.
You could pull off the CMSL and check the wiring colors.
Then (if the wires run in the same spot as the gmt-800s)
chase the wires down the rear left corner B pillar, under
the left side floor covering, and up to the headlight switch.
Then disconnect said wires and mount along with a new switch and hook up to a hot power source.
I don't know why they didn't wire it to come on with the reverse lights also. :puke:
Because then it'd light up the bed and reflect off of the tailgate. I've tried backing up with mine on, and it doesn't work at all (makes the bed bright, so everything behind you looks even darker).
