R&d Test Vehicles Needed
spyder_auto
Hello all, I currently work for a company that manufactures headlights, taillights, foglights, etc. (www.spyderauto.com)
We are currently looking for the following vehicles to do test-fitting for our new products:
1. 03-05 CHEVY SILVERADO (projector foglights)
2. 02-06 CHEVY AVALANCHE (projector foglights)
3. 04-07 FORD F150 (projector foglights)
4. 97-98 FORD F150 (projector foglights)
5. 97-98 FORD EXPEDITION (projector foglights)
6. 99-03 FORD F150 (projector foglights)
7. 99-02 FORD EXPEDITION (projector foglights)
8. 01-04 DODGE DAKOTA (projector foglights)
9. 01-03 DODGE DURANGO (projector foglights)
10. 94-01 DODGE RAM (projector foglights)
11. 99-02 GMC SIERRA (projector foglights)
12. 00-05 GMC YUKON (projector foglights)
13. 02-04 JEEP LIBERTY (projector foglights)
14. 98-05 VOLKSWAGEN BEETLE (projector foglights)
15. 97-00 DODGE AVENGER (projector headlights)
16. 99-06 CHEVY SILVERADO (taillights)
17. 95-01 CHEVY BLAZER (taillights)
18. 93-01 CHEVY CAMARO (taillights)
19. 00-05 CHEVY DENALI (taillights)
20. 99-04 VOLKSWAGEN JETTA (taillights)
21. 04 CHRYSLER SEBRING (taillights)
22. 97-01 CADILLAC CATERA (projector headlights)
please PM me or call 909.638.8948 (ask for Justin) MUST BE LOCATED IN SOCAL (near City of Industry, CA). you will be compensated for your time smile.gif thanks.
:cheers: ?
This guy might be legit,City of Industry is a city in So Cal(not too far from Pomona).The prob is not too many guys on this site could take advantage.If I had a vehicle like he's asking for I might give him a call.I used Pomona 'cause that's the most likely to be recognized by outa staters......
If this is legit, it must be approve by the mods and admins. I call :cheers:
You're right,didn't think of that....my bad :dunno:
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
