Gear Infomation
markhd3500
Hello, I am a new owner of a 2007 3500 HD crew cab, I am looking for axle gear info so I can understand the full towingh capacity of the truck. Any way to identify that from vin or something?
Thanks, Mark HD
Thanks, Mark HD
Look on the RPO sheet in the glovebox
GT4 is 3.73
GT5 is 4.10
Thanks, Mark HD
GT4 is 3.73
GT5 is 4.10
^^^ What he said.
Welcome to the ZOO!
Thanks, Mark HD
GT4 is 3.73
GT5 is 4.10
^^^ What he said.
Welcome to the ZOO!
:cheers: Welcome aboard :dunno:
