Price's
I just got this in a email from my dealer Example #1: $20,278 MSRP (2008 Silverado Regular Cab stock #081668)
-$6000 Rebates
-$786 Supplier Pricing
$14,387 Your bottom line Price!!
Ecample #2 $36,468 MSRP (2008 Silverado Crew Cab stock #081697)
-$8000 Rebates
-$2695 Supplier Pricing
$25,773 Your bottom line Price!!
It's hard to argue with 14k for a 2008 truck :crackup:
Regular cab trucks are sweet anyway :dunno:
+450 Bazillion
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
