Ok, What The Hell...
Frank S
Someone care to explain what this white crap falling from the sky in southeast Texas is? Better yet, why the hell is it below freezing now? Did the Cubs win the World Series while I wasn't looking or something?
What the hell you doing outside? You should be fixing this damn site!!! :P
:D
+10000000000000000000000000000000000000000000000000000000000000000000000 Infinity!
:D
I just hope hell doesn't freeze over first before this site is fixed! :D
:P
:D
Seems to be working fine to me. Besides that I'm a forum admin, not a site admin. I'm basically just a virtual baby sitter. :D
What the hell you doing outside? You should be fixing this damn site!!! :D
:P
HAHHAHAHAAAAAA
( In case the Forum doesnt auto double/triple/quadrouple post for me like it has been the last 2 days, then)
HAAAAAHAHHAHAHAHHA
HAHAHHAHAHAHHAHHAA
There. :D
Some damn yankee must have left the door open...
Just wait 'til the tree-hugging hippies here about that....! All that wasted electricity! :P
:D
Just wait 'til the tree-hugging hippies here about that....! All that wasted electricity! :D
:D
Hey! I live amongst them, now! Don't piss them off :P
:D
Well, Mr. Babysitter, can you go check on the kids and make sure they are still workin' on the site? :P
I honestly think it's getting worse.
Oh, and that white stuff, that's just cocaine, don't mind that. The Clown is throwing a party. :D
And it was f*cking 65 here today. What the f*ck? I think someone flipped north and south or something... :D
Trade ya? They're calling for 25 here, tonight...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
