Scheduling Muffler Swap For Next Week
I'm planning on having my Flowmaster Super 40 put on my truck next week. There's just a few questions I'd like to have an answer to before I do so.
First, is the only effect to factory warranty the muffler? I know GM isn't going to cover a Flowmaster muffler but say I take the truck in for service and they see it on there. That wouldn't void the remaining warranty on the rest of the truck, correct?
A question for y'all that have had a muffler swap done before: How long could I expect this to take? Would it be quick enough that I could stand there and wait or should I try to get a ride home? More than a day? I'm having this done in a town about 10 miles down the road so walking home isn't much of an option now in the middle of December.
The place in town that I was planning on having do the work just told me the other day that they don't do other "people's" mufflers. I guess "people" meaning Flowmaster. So I called around and found this guy in another town. When I asked him about a muffler swap he asked me what I meant by that. I told him just cut the stock muffler out and put a new one in. He said "WELL SURE!" So as long as he has the extra piping needed to fit the shorter Flowmaster into stock pipes then I'm planning on having this done next Tuesday or Thursday. I'll be sure to get sound clips for y'all.
Correct. The only warranty effect is the muffler, which, of course will be gone...
For a good shop, expect 15-20minutes after it's up on the rack. That's what mine took. I stood there, BS d with em and waited.
That fm40 will be LOUD, with a LOT of resonance in the cab. I tried a Delta-FLow 50, and ended up selling that one to a buddy, and went with a Series 70 Big Block II. In my pre-Alzheimers age-range, the interior drone of the 50 was too much for my liking. But, this is a matter of personal preference and taste. :P
Yes, posted sound clips (before and after) are considered almost mandatory on the forum !!!!!!!
:D
I've been trying to watch a lot of videos of exterior/interior noise with Flowmaster 40's, 44's, and 50's. I like to hear a bit of that power sound inside the cab. I assume if I do end up not liking it, it can just be swapped for another muffler or back to stock just as easily?
It can, of course. You may need to buy a second muffler and sell the first one. Ask the shop to give you the OEM muffler, and ask them to cut it off in sucha way that it COULD be re-attached. If they cut the old one off right at the muffler wall, it makes it much more difficult, if not impossible, to put it back on easily.
Grumpy Aero Guy covered all the bases really. To have my Magnaflow put in, it took maybe a half hour from when I tossed them the keys. As far as the warranty stuff goes, it should just be your exhaust system that is affected. The muffler by no means changes anything else(significantly) and doesn't matter because of that reason. You'll want to keep that stock muffler since someday, you might want to go back, and they cost a bundle to buy from GM. The list price, even on GMPartsDirect is crazy expensive.
Be prepared to hear it sound different. When I had my MagnaFlow put on I walked over the the dealerships next door and came back. They'd taken my truck off the rack and had it just sitting out in the lot. I went out there and started it up and boy, I was shocked. Let us know your thoughts and maybe a sound clip or two. I still need to do mine...
It can be swapped out easily. If you like loud, the flowmaster you mention will be fine. The other questions have already been answered (very well too).
The thing I would worry about is how he is going to install the new muffler being welded in, is he going to install it butt to butt or sleave it like it should like say 3" OD to a 3" ID, If he butt welds it to the exhaust pipe after the convertor the welds will rust fast and leak, make sure he sleaves it.
I've got a 3" in/out muffler with 2.75" stock piping. Would that setup require a sleeve weld or could it still be butt welded?
I know I'm paying for it and it's my truck but I still don't like giving the impression that I'm trying to tell him how to do his job. Would the size differences in muffler diameter to pipe diameter perhaps prevent any problems?
As long as there is a good 1/2 inch or more of overlap at the joints and they are welded tight, I think it will be fine. My shop had some sort of zinc / aluminum exhaust paint in a spray can (rattle can) that he used on the welded joints. It hasn't been on there too long but it has held up to the heat and still looks like it did the day he did it. The aluminized tubing should last 5 years in a caustic environment... maybe more.
I went on down today and checked everything out with the guy at the shop. He looked at it and said everything should be OK. The only problem he said would be fitting new pipe for the shorter Flowmaster muffler. I don't know if he makes the new pipe himself or what though because he was saying how it is a totally custom shop and he said it would take about half a day and $50.
Anyway, I'm scheduled for Tuesday morning and should have my truck back to me by lunchtime. I'll try my best to get video/sound clips up. It'll be my first time posting a video so I'll have to try to learn how to do it first.
Thank you all for your help. I appreciate it so much.
The half day surprises me... the $50 seems pretty reasonable. I think my shop charged me the exact same. CAR-X wanted $135 just to put the muffler ON, assuming I supplied it... :lol:
They put a section of pipe on mine too. FM was about 4" - 6" shorter than the stock muffler, if I recall. That OEM muffler was a monster.
The 50 was even shorter than the 70... LOL (the 70 is quite a bit beefier than the 50)
I'm not sure if the half day is because they are just that custom or what. I don't mind the half day though as long as it's done correctly. I'm off work that day anyway so I'll get to mess around with a new muffler :lol:.
The stock muffler definitley is a monster. I think I measured it at something like 21"-23" not counting the inlet and exit.
When I get my muffler put on will I have the "true" sound from the first startup or will there be a break-in time before it sounds the way it was build to?
I'm not sure if the half day is because they are just that custom or what. I don't mind the half day though as long as it's done correctly. I'm off work that day anyway so I'll get to mess around with a new muffler :dunno: .
In my case, the sound was there with the muffler. As you drive some, it will "burn in" a bit, and the note will change a LITTLE... but it will "be there" as you say, on start-up.
again: DON'T FORGET THE SOUND CLIPS..... ( :happysad: )
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
