Tranny Fluid - 2000 Sierra 2500 4wd
pkeithkelly
I just purchased a used 2000 Sierra 2500 4WD, with 5.7L
I want to change the manual transmission fluid, but have 2 questions:
1. how much fluid to add after draining? The tag on the case says use Castrol Syntorq LT, GM PN: 18306
2. I can see the leveling plug, but no filler plug or drain plug - what gives?
appreciate the help.. This is a great truck.
Keith Kelly, Encinitas, CA
Keith,
Look into your manuals that came with the truck, OR call your nearest service dept. and ask what the capacity of the box really is. OR drain the fluid into a pail large enough to hold it,(manual box shouldn't be much). Match that amount and pour the same amout in place of the old oil. That should do it. This isn't rocket science! P.S. Too much is a lot safer than not enough!
I would love to drain the fluid. My problem, and the reason I posted the question - I don't see a drain plug. Just a level-check plug halfway up the case.
Can you tell me how to drain the fluid with no drain plug in sight?
Thanks.
Keith
Thanks.
Keith
You might have to remove the pan to drain it :happysad:
Thanks.
Keith
Its not an automatic. It does not have a pan.
Don
Thanks.
Keith
My genuine GM 2000 Silverado, Tahoe, Suburban, Sierra, Yukon, manual seems to be only for the New body with the 4.8, 5.3, 6.0 eng type. However, the transmissions may be common. If yours has a NV 4500 manual trans, it has a 4.0 quart capacity of the stuff you mentioned above. If it's a NV3500, it holds 2.2 quarts of "Synchromesh Transmission Fluid GM P/N 12345349"
A quick look at the difference between a NV3500 and the NV4500 shows the 3500 has an integral bellhousing and many exterior ribs with a tapered tail shape. The 4500 has a separate bellhousing and has a very boxy shape like old manual tranmissions of yesteryear and a flat aft gearbox surface for the tailshaft housing.
If it's a NV4500, the drain plug is just below the fill plug. It's hard to tell in these pix because they never show the drain and fill plugs in relation to the whole transmision, but it appears that they are both on the right side of the main box near the tail shaft housing end.
Thanks for all the helpful suggestions guys.
Yes, there is a stamping on the driver's side of the tranny casing that says "4500" so presumably its the NV 4500.
And yes, it has a boxy shape. The filler plug is clearly visible on the passenger side of the case and has a plastic tag on it saying use only Castrol Syntorq LT. The plug takes an Allen key. I removed it yesterday and stuck my finger in to check the fluid level. It was OK.
However, I am 100% certain there is no drain plug below it, or anywhere on the tranny case for that matter. I was under the truck 3 times with a light. There is no drain plug. However, there is a flattened round area on the case below the filler plug, which looks like a logical place for a drilling for a drain plug. But none there.
A mystery.....?
Keith
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
