Help Me Pick A Mudtruck
Sierra250004
all these are 3000 dollars or cheaper.. high miles of course but seem to run well with no problems needing to be fixed..
Help me choose.
The one with the cleanest, dry, least scratched under carriage.
Help me choose.
Are all those Jeeps 4cyl or 6? If you play in the mud alot I'd go for the I6, the manual tranny in the 4cyl (ax5) is a little weak. The last one has some awful tall shackles and the springs look flat. Stay away from anything that has more than a 2" body lift. If any have a suspension lift check for vibrations while driving. The rear drive shaft angle can get too extreme around 3-4" of lift. Easily fixed with a slip yoke eliminator kit but added expense.
For a better idea of what to check for go to Jeepforum.com and check out the "YJ" tech section. Good bunch of guys and lots of good info. Enjoy the Jeep which ever one you decide on and don't forget to wave!!!
Help me choose.
Based on looks alone, I like this one the best.
the first pic is way too small to tell anything about it, but all the others (last one most of all), have way too much tire for the lift. They're all going to have rubbing problems with any decent flex.
Also, I second the suggestion of checking out jeepforums.com. It's a great community with massive amounts of info.
jeeps are for little boys buy a real truck
Guess what, stud...a Wrangler will wheel circles around your truck all day long.
Guess what, stud...a Wrangler will wheel circles around your "real" truck all day long.
+1
(and fixed) :gmc:
I want to see that top one. Looks like a Cherokee with an exo-skeleton and a beefy bumper.
