Cigars
P'cola Denali
For my birthday the girlfriend got me a box of Devilsweed cigar and a few Solsos. I was woundering what you guys smoke? A real cigar means you have to clip it and it dosn't come from 7/11.
Devilsweed is from here in Pensacola. They rented the shop next to mine for awhile when getting started and I got to know them really well. Great guys and they make a great cigar.
My old roommate was into the Cohibas. They were a little heavy for me when I first started smoking cigars. I had a Davidoff for a friend's bachelor party, and it was really good but way too expensive. Now I prefer the Aston VSGs.
On my last cruise to Cozumel I got some Cuban Montecristos. They were really darn good too.
When I'm in the mood for a cigar I smoke Antonio y Cleopatras,brown wrapper.My dad used to smoke King Edwards...yuk.But that was after he retired and was on a fixed income.5 cigs for $3.00 eeewwww.Oh well he liked 'em
I perfer the Robustos and Maduros.
In the Humidor Now: (Remembering off the top of my head, I know I have more)
Cohiba -Lonsdale/Cameroon
La Gloria Cubana -Corona Gorda/Natural
Punch -Double Corona/ Natural
Bolivar -Lonsdale/Conneticut
Rocky Patel 1990, 1992, and Sungrown
Onyx Reserves -Robusto/Maduro
Gurka Black Dragon
Arturo Fuente -Privada #1/Natural
Romero and Julieta -Robusto/ Natural
Davidoff -2000(Thousand Series) Aniv No.2(Aniversario Series) Churchhill Sungrown(Millennium Blend)
Navarro -Torpedo/Maduro
I love smoking cigars.
Too bad I don't smoke them very often because the day after I smoke a couple, my mouth tastes like a cat crapped in it.
I smoke them once or twice a year. I'm brands i'm fond of Avo XO, Cohiba, Punch. And anything my friend Wayne hands me when i'm at his place because he thinks nothing of spending $15-20 on a stick, and at that level, they're all good :cheers:
I don't really enjoy cigars, but I sure smoke the hell out of Camel non-filter cigarettes. :jester:
I had to switch to Camel filters.
After about 40 years of smoking the non filtered ones, they were starting to make me cough.
Stick with the Dry filters they have less OIL!! Those Dam filter less ones will get yea every time!!
