mjrodg
I'm Mike from Pittsburgh. I just traded in my '96 Sierra and bought an '09 Silverado 1500 Z71 LT1. I've been looking around on here for a few days now and it seems like a lot of the people here have pretty good knowledge of whats going on. I'm not looking to do too much accessorizing, but there are a few things that I definitely want to do. Add the DIC (already ordered) and steering wheel audio controls, (some questions I need answered first). Anyway I'm glad to be here and look forward to chatting with everybody
Welcome!!!
I'm right below you in Greene County.
Welcome Mike!
We call it the way we see it and if we don't see it, we make it up!
:thumbs:
Welcome Mike!
:thumbs:
I KNOW NOTHIN'
MS3DALE, I love the license plate....awesome. I'm in Allegheny County, so yeah pretty close. Nice to meet everyone. "Welcome Mike! We call it the way we see it and if we don't see it, we make it up!" Haha, if thats what works, then good!
