Couple Questions On A New Truck
Hi everyone I have a new to me 2007 Chevy Silverado and it has heated leather seats with the power seat option. Anyways it also has 2 memory settings. How do I set them for myself and someone else, and keep them in memory. Also anything the 07's are known for having problems, my 2000 did the cold start knock and that was it.
The memory is tied to the keyfob that opens the door. You will notice one is #1 and one is #2. What ever settings you use with #1 will always be used when you open with the #1 fob etc. Give #2 to whoever else drives the truck and they can set it to there specs.
Congrats on the new ride. To set the memory, adjust you seat, mirrors, etc. to the desired position and then just push and hold the memory position (1 or 2) until it beeps and you're all set.
Crazy
That was true on the GMT-800, but on the GMT-900 the remotes aren't coded or marked 1 or 2. You have to just use the button on the door panel to select which setting should be used.
As far as I know, no. 26k miles and zero problems!
Thats why I love this site everyone helps everyone out. Love the truck, feels a little softer than my 2000 which is a good thing and it seems to have a little more pep too. What is the issue with the transmission at the bell housing
Anyone have a link to the thread
Not true...mine are.
i.e. when using the "Exit seating" feature, when you press unlock on the remote FOB, it returns to the memory seating assigned to that FOB. I found this out the hard way when I got my truck. I would set the seats the way I wanted them, then I would press the unlock button and the seat went all the way forward. I thought something was f'ed up. Then I discovered I had the #2 remote and it was putting the seats to the #2 memory position.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
