Sugar In Gas Tank?
kristenc
Could sugar in my gas tank cause this? I have a 2002 GMC sierra 1500 5.3 and it runs like crap. The check engine light blinks and the codes are PO174B-Fuel trim lean bank 2, PO300B- misfire detected, PO151B-HO25 circut low voltage B251. I just replaced the intake manifold gaskets and it runs the same. I cant go over 70mph and thats with the rpms between 400 and 500. We are having a hard time figuring out the problem. It has a new fuel pump, fuel filter, new plugs and wires. Any advice?
I would venture a guess that the PO151B-HO25 circuit low voltage B251 is causing issues with the fuel injectors resulting in the other codes. I'm not sure what PO151B-HO25 circut low voltage B251 refers to exactly but I would suggest looking into that one more.
Have you tried testing the O2 sensors as advised in other posts ?
sugar in a gas tank dosen't do anything. Urban legend.
+1. They did a segment of this myth on Mythbusters and it was Busted.
