Having Trouble Starting Truck In Cold Weather
Hi there. I know a lot of basics about my truck but I'll be the first to admit I don't know nearly as much as I should.
When its been getting really cold here (under 8 degrees) my truck (2002 1500 Sierra) is having a lot of trouble starting. I thought at first it was the cold amps (which would be a nice easy fix) but my battery is running strong. I listened more carefully and it sounds like the engine just isn't getting gas. After I turn it over for awhile it seems the pressure gets up enough that it gets gas and the truck starts (usually after trying to start it for 5 minutes or so). I believe this has something to do with the fuel pump - but that is where my knowledge stops. I know it might be the sensor going - or the fuel filter, but before I go get it looked at I'd like a better idea of what it might be. I'd imagine it has something to do with ice forming (since it only happens when its really cold) but I was hoping someone might be able to help me out? I know it is definitely from the engine not getting gas right away, what would cause that in really cold temps?
Thanks.
Any "check engine" lite on dash when it does start? If so, get the codes checked out. Also could be the fuel pressure regulator, which isn't that expensive to fix.
No check engine light.
I'm gonna try to take a look at changing the fuel filter (haven't tried that yet though) and hope that helps. If not I'll have to bring it in.
Can you hear the fuel pump prime itself when you turn the key on? Did you check the fuel pressure at the fuel rail? It could quite possibly be the fuel filter. Let us know what you come up with. :lol:
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
