Sirius External Hum/feedback
I have a starmate 4 and I like it, I wouldn't get one of those built in units for anything. My problem is that even though I am connecting it to the stereo directly it seems to hum. You can actually hear the revs of the engine thru the stereo with it plugged in and even sometimes it will pop when you press the brakes. I don't think its the actual sirius unit (being that I use it in multiple cars) but more the 12v adapter I plug it into. I have tried all of them, both in the dash, the one in the center console and the rear seat unit as well. I imagine they are all wired together but heres to hoping.
Anyway, anyone else have this problem? Could it be a bad ground?
Back in the day when I used to do stereo installs I remember this being the issue, that and running the power wire on the same side as the alternator.
Oh, one more thing, anyone figure out a way to keep the damn 12v adapter in the outlet? I hit a bump and it becomes dislodged! Kinda annoying.
I didn't a search but didn't really come up with anything that I thought was relevant.
thanks
It is a bad ground. The 12v adapters are creating grounding feedback loops, which is the hum you hear. If you unplug it from that adapter you'll get rid of the noise. I've got the same problem using my line-in for my ipod. There are a couple ways to fix it, but it involves basically re-grounding the adapters individually, or grounding your unit that goes into the adapter.
Then again, the alternator option sounds like it could be viable also, which would be why the hum changes with the load on the engine. I've just decided that I'm going to eventually get the PAL that connects to the XM unit in the glove box and ties into the Ipod there. There It'll charge and play on the radio. I don't know if there's any options like that for a sirius unit or not. How do you have it wired into the radio?
I have it connected using the headphone jack. I don't mind ripping the dash apart and regrounding these things if its going to let me enjoy the sirius radio again! Right now I am at my wits end and don't even bother with it, I have been listening to my MP3 player instead but it eventually kills the battery and then I am back to my sirius hummage.
damn GM and their shortcuts. Maybe I will run a wire right back to the engine. Are all 4 adapters wired together?
oh, this is in my 07 silverado
The Starmate dock is permanently installed in your truck right? If it is, I would just buy an extra 12volt outlet, install it somewhere hidden, and then plug the dock into that. That should eliminate the noise if it's wired properly, plus it will clean up the wires and give you back all of your factory outlets.
Just so you know, you can't just cut off the plug for the dock, IIRC, it has a 12-to-5 volt transformer built into the plug.
  • 2 months later...
so I just took the dash apart. I tried to ground the 12v to the body and then straight to the battery. Nothing helps. Are we kidding here? I even disconnected the stock ground and replaced it with this ground to the battery and the body. Then I disconnected the power from the 12v and the ground was still noisy as all hell! This is freakin lame! On top of that, I broke the stupid lil 12v cap! UGH! So I am completely annoyed. Anyone have any other ideas? Can I get a ground loop isolator for the ground of the 12v?
I get hum with my radio (less now that I have it direct wired into the antenna vs. using the aux. jack). I also get hum with my CB, even my Onstar phone. Pisses me off. Complain to the dealer, and get blank looks, followed by 'it must be your devices'. Yeah, it's my devices, not the truck.
I have the sportster 5 which I have hardwired in. I bought the iSimple PXAMG which allowed me to hook my sat radio in to the back of the head unit (and also my iPod) and then I bought an extra cigarette lighter outlet and wired it in behind the dash so it couldn't be seen as was mentioned earlier in this thread. Works like a charm and I don't get any feedback.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
