Wax Or Polish Which Come First.
Is it best to wax first and then polish or to polish first and then wax.
Polish first, then wax.
+1
+1 more.
The wax is what protects the finish after you polish it to a good shine. Polish is generally only used on finiishes that are damaged, scratched, or dull. Otherwise a good cleaner/wax does the job nicely in one step.
Wax on.
Wax off.
Good question. Once in the spring and once in the fall, I do the clay bar thing followed by one coat of Liquid Glass polish, then 2 coats of Meguires NTX wax. The rest of the time I will just do one coat of wax to keep the shine.
Ok so here is my plan for the spring on the first nice day I get.
-Wash
-Clay
-Paint Cleaner
-Polish
-Wax
What is the difference between a Wax Cleaner and a Carnauba Wax ?
-Wash
-Clay
-Paint Cleaner
-Polish
-Wax
Cleaner wax typically has some paint cleaners, some polish, and wax. So it is sort of a 3 in 1. Carnuba wax is just that.....wax.
Your plan looks good.
excellent plan. Every spring I use meguiars paint cleaner to get any salt residue off the paint, then follow up with a nice polish and nxt tech wax.
I've had good results with Meguire's Gold Class wax.
+1 Good stuff :D
You might also try Meguiar's NXT 2.0 - the new version supposedly lasts longer than the original.
I'm just waiting for a semi-nice day on a weekend so I can buff out all the swirls and holograms on my black truck, polish with Meguiar's #80 and finish off with NXT 2.0.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
