Finally Some Snow!
RyanbabZ71
Sucked to get home but it was fun playing with the dog and snowblowing
Holy Crap!!! It's 60 and sunny here on the South side.
Awesome do you have an extra lawn chair out? After I go snowblow again I will be over.
no, snowblowing is not fun. we got 96" in the month of december so my view may be tainted with disdain. great looking dog you have there by the way.
We got 1/2 inch snow and sleet today! Yes sir, they called off schools for miles around, called out the national guard, governor called a statewide state of emergency, etc....you know the drill.... and you thought we were a bunch of wimps down south .... when it comes to snow/ice, we are... :)
:D
we are well below avg for snow thats why I am excited.
We are getting freezing rain right now...I guess this is as close to winter as I can hope for. Although it has snowed the past 2 easters here.
    • Correct.  2019-2020 are serviced by a different p/n.  19420611.   The recall engines 2021-2024 are serviced with 12740076.     What the difference is between the two, I'm not sure, but 2019-2020 only show 19420611 as the replacement engine p/n.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
