$1035.00 O2 Sensor
Took my 2004 GMC Sierra to the dealer for the instrument cluster issue in my case the gas gauge was reading well above full and not returning to zero I already know it’s the gauge because the range reading on the DIC is correct.
They tell me to make an appointment and bring it back I tell them no! I need a tech to see it while it was actually malfunctioning because the problem was intermittent and the dealer had already refused to replace it once before.
Reluctantly the service manager takes a look and says that he has to scan the instrument cluster before he can order a replacement. He scans the truck and orders the part and sets up an appointment.
The bad news less than 24 hours after dealer scanned my truck the check engine light comes on (cycling between steady and flashing) with rough idle and ODB code P0300 random misfire. The misfire only occurred after engine was warm (closed loop) and there were no other codes.
It takes the tech 5 hours to diagnose the problem. He advises me that an O2 sensor NTB replaced and that I need to clean the plenum, flush the injectors and change the plugs/wires. Total repair bill $1035.00 for an O2 sensor. I ok the repairs.
BTW the diagnosis was a split between the left and right bank O2 sensors.
My question is it possible that the dealer induced the failure or is this just a strange coincidence? When he scanned the instrument cluster the truck was in the bay about 30 minutes.
it is possible for the dealership to mess with anything they want. hell all that they would have to do is 'turn off' one of your modules through the BCM and cause the service light to come on. I am not saying that they actually did it, but I point it out because the one dealership that actually did it was Potamkin Cadillac Buick Chevrolet Mitsubishi GMC Saab Hummer down in New York was a bad dealership. If you dont believe me, read it for yourself:
http://www.nydailynews.com/archives/news/2..._rise__fed.html
They 'claimed' that it was only two mechanics, but our DVM out there actually found customer Hummers and Cadillacs that were in for service being used by the dealership personnel to store the drugs. I know that some dealerships have come up with 'questionable' diagnosis over the years. I would have probably gotten a second opinion though.
Reminds me of the DeLorean story.
The light did not come on until the next day after about 20 miles of driving.
I pulled the code myself P0300.
Though I would let the dealer give it a try since the truck needed to go back for the instrument cluster.
Also I was hoping the problem was be covered under the emissions warranty I should have read the fine print only the cat and ECM are still covered.
As far as I know there are no data logs that can be pulled from the computer that would indicate any tampering.
There is your problem. Even is the dealership raped you on the sensors, you paid $150(gestimate) an hour for labor. That is ridiculous!
Actually, it was 92.00 an hour but getting raped by the dealer isn’t the question.
Is it possible to extract data files or event logs from the ECM? What I’m trying to figure out is possible to prove it was sabotage.
How many miles on the vehicle? O2 sensors usually last between 100k - 150k miles. Might just be coincidence if your mileage is up there.
Or, maybe not on purpose, but on the lift they could have pulled, shook or damaged the connection with the pre-cat O2 sensor. I know when I replaced these on my BMW, the wires ran up from sensor to the top portion of the engine, held in place by plastic clips and the connect was held together by plastic clips. Not sure where they are on these trucks, but I'd assume similar.
A very good tech/computer tech might be able to figure it out. Might. The tech would have to be very familiar with the ECUs and software to interrogate them.
Cleaning the plenum, injectors and replacing the plug wires is all, most likely, added work that did not need to be performed, or you could have easily done yourself.
At this point, it is very, very unlikely you could get a case to standup. Besides, things do "happen". 25,000 miles is very low for an '04, and age can kill sensors and such as well as mileage.
I had an O2 sensor go in my 04 Avalanche at 16,000km. Seemed to happen after going through some deep puddles on a flooded road.
The reason they scanned your cluster was to get the vin and mileage info so the new one could be programmed with the correct mileage and VIN. The chance this caused problems is 1 in a million at best.
I understand why he scan the instrument cluster before ordering a replacement and I don't believe that caused the failure. I work in aerospace and I'm well aware that anything can fail at any time also I have witnessed numerous maintenance induce failures.
I'm more concerned about the fact that a dishonest shop can disable a module and induce a failure without the customer ever knowing he's been had.
I take it this isn't something I can do with an off the shelf scanner and a laptop.
What does that mean? Did you have a wiring problem or were there two bad O2 sensors? Or something else?
You got ripped.
Your bill should be $0.00
Your 0-2 Sensor falls under Emissions Warranty 8 year 80,000 mile coverage. Believe me, the dealer can get this fixed for $0 if he wants to.............
I'd be on the phone with a GM rep ..................
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
