I'm A Seeing Things?
I don't think it was the shops idea by the look on the "mechanic's" face.
That's so much awesome, even having Chuck Norris and MR.T in the same room is no comparison to the awesome that is This truck. :D:seeya:
I'm more upset with the RWL's. :seeya:
RWLs don't kill.
Well, maybe if Daddy sees them and runs the f*cker off the road. :smash:
:D
:D @ Jenga.
And I just realized something else. That's a 14b, and as far as I know, the HDs never came with a block from the factory. That makes it even worse. :seeya:
Everything in that pic is like an accident waiting to happen ...
and could've been posted in the "Show Us Your Fail" thread... :D
WTF? Isn't the u-bolt plate supposed to be on the bottom? Also they are supposed to go OVER the leaf. That set-up looks like it could slide along the leaf. JESUS! I REALLY hope that is a good photochop!
:D:seeya::smash:
Hope all you want man....I REALLY think its a stupid person....And a new Candidate for This years Darwin Award is.....
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
