1993 Chevy 4x4 Not Shifting
I just traded a guy for a 1993 k1500 and on the ride home it was fine except I noticed the speedo said I was going really fast and I didn't feel like I was then all of the sudden it quit shifting right. It will definitely do 2nd and may be 3rd I think but when I downshift through the gears it doesn't seem to go into 1st and 4th will increase rpm's and that is basically it. I feel like it is in neutral when I reach that gear. I have heard ignition switch, speed sensor, and/or solenoids but was wondering which is most common. I really appreciate any help because although it looks good sitting I would love to actually drive my truck. Also how could I be sure which gears it is shifting into?
I agree, that is a nice bike!
If I can decipher the expression of unintelligable babble on the vehement perplexity in confabulation concerning your initial post,... I would say, refract from deliberation and cosolation at this juncture.
Sounds like a problem more serious than a sensor or solenoid.
You may benifit from an entire rebuild. I can only imagine that your internal seals are not holding any pressure therefore doing more damage than good durring your forward progression. You will probrably find that you are having torque converter issues as well. When your power is lost, perhaps slipping thru the gears as opposed to "shifting" thru, the loss of pressure will not allow the torque converter to stall appropriately. There are too many variables to list here.
Take it to a tranny shop ASAP!
Not a national chain shop either, take it to a local guy that has been in business for more than 15 years. Any national chain is programed to tell you "You're lucky to have made it here. You need a New transmission now!".
Good luck!
Keep us posted on what the problem turns out to be.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
