4l60e Interchange
I just baught a 2000 4x4 yukon with a 4.8 and a 4l60e
the trans make a funny noise during the 1-2 shift
also the 1-2 shift seems kind late and soft
all other gears are ok and trans does not slip
truck has 160k
anyway i have a wrecked 99 awd astro with 90k
can i pull the trans out of the astro and put it in the yukon
gm list both trannys as having different part #'s
gm also list 3 different tranny part #'s for a 2000 yukon they list 4.8 5.3 and 6.0 as all having a different trans
whats the difference gear ratio??? shift points???
any way will the astro trans work in the yukon
and if not why not
thanks in advance
I'm not too knowledgeable with 4x4/awd, but since the Yukon trans is 4x4 and the astro is awd it might have a different output shaft..but the output shafts should be swappable since their both essentially the same transmission.
The astro has a 4.3L V6 off the "Lt" 305-350 engine platform and the 4.8L is the "LS" two different engines and will not work.
If I'm reading it right he is asking about the transmissions, and if you are getting a 4l60e out of the van and installing it in the truck that had a 4l60e I don't see why it wouldn't work. Swapping transmissions really isn't all that hard so why not give it a try and see what happens. Just don't use the AWD transfer case.
The two different engine platforms do not interchange, GM changed the bell housing and the offset between the bell housing face and the crankshaft face.
Well there you go! You learn something new every day! Thank you.
that the kinda info i was looking for
so why can't i just swapp bellhousings
The input shaft may be different, the output shaft also & the wiring too. The Astro is a lighter duty than the Yukon. All the work to put an old transmission and have it fail is a possibility.
I have access to a salvage yard interchange index. Here is a list of transmissions that will work for your truck.
SIERRA 1500 PICKUP 99-00 A.T.; 4x4, 4.8L
SILVERADO 1500 PICKUP 99-00 A.T.; 4x4, 4.8L
TAHOE 00 A.T.; Silverado style, 4x4, 4.8L
YUKON 00 A.T.; 4x4, 4.8L
Ident: KBD
4 spd. A.T., 4L60E, M30.
Pan has 16 bolts.
sorry for the hassel but if you look up a tranny for a 2000 yukon in the gm parts catalog
it lists 3 different part #'s
1 for if it has a 4.8 engine
1 for a 5.3 and 1 for a 6.0
but i am sure i could pull the 4.8 and dropp in a 6.0 with out any problem and keep the same tranny
i was just tring to find someone that knows for sure
thanks for all you help
Each trans is built for each engine size and the 6.0L is a 3/4T and is a 4L80E not a 4L60E. Also make sure in those years 2000-01 that you have the transmission for that model year because they wont all bolt up because of the crank off set difference.
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
