Fs: Diablo Sport Programmer
Dano07
I have a used programmer with the latest firmware and i also have the plug and USB adaptor to connect it to the compter. I am looking to get $275 shipped for it all. Not sure if i am asking to much. it has been reset. It was used on a 2007 Silverado.
Model # U7194
Why are you selling it?
I could use the money since we just had a baby on 2 feb. I eventually would like to get the edge, but that will be a while down the road.
oh congratulations man.
Im guessing that you didnt get the performance gain you were hoping with the predator since you say you'd like to get the edge? Did you try dialing in your LTFTs with this programmer and did it make a difference? Thanks
I only got the programmer to be able to turn the AFM on and off and also to be able to change my tire size when i got my new tries and to be able to read codes whenever need. i didn' get it for a performace factor. My brother-in-law has the edge and i like that you can monitor different things while driving.
I know someone out there will get good use out of it.
I had an Edge, don't waste your money! If you want the PID displays, just get a scangauge, they are about 1/3 the price.
The Edge Evo sucks!
The Edge does NOT allow you to turn off AFM or make any custom changes to parameters. It does NOT alter TM or any other nannies.
Even the tire size and gear change options suck. You have to re-enter those changes EVERY time you switch tunes.
(disclaimer: this info is based on a year ago, if they made any changes in the past year, then some of this may not be accurate).
Thanks Dan.
I ask because I'm interested in it so I appreciate the responses.
No problem on the response let me know.
  • 1 month later...
