2006 Avalanche Tpms
I just bought a 2006 Avalanche which was a theft recovery vehicle. I am wondering if 2007 Avalanche wheels with TPMS will work on my 2006 Avalanche. I appreciate any info on this.
Hey there and welcome to GM Trucks! :thumbs:
I'm not sure on your wheel and TPMS question, but others here should be able to help.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
