Sir-gm1 Stopped Working
I installed the SIR-GM1 with the 1 foot pigtail, replacing my XM module. I called Sirius, paid for activation plus one month's service, and 4 hours later, I went to drive home from work, and all I get is 'XM ERROR' on the HU display.
Anyone have any experience with this? I googled and come up with a few things, like shutting the key off and opening/closing the door, but that did not work. I called Sirius, and they were no help at all.
Anyone know a way to reset these devices, or anyone ever fixed this issue?
Don't call Sirius, call Directed - http://www.directed.com/ContactUs/TechnicalSupport.aspx
They said as of Febuary 1st, 2009, they handed support of all of their sirius products to Sirius.
Sirius walked me through some troubleshooting steps, mainly turn HU off, unplug and plug back in, try it. Turn HU off, open door, close door, try it. Disconnect battery, reconnect, turn HU on, try it.
So they determined it was a bad unit. They told me to go to a Radio Shack and have them test the unit.
I am headed out to one this afternoon.
How'd it go Jeff?
From what I read online, the only fix is to completely shut off the vehicle, open & close the door & restart the vehicle - that's a shotty work-around!
How'd it go Jeff?
Radio Shack did not know what Sirius wanted them to do about my issue. I have to call Sirius back and get them to call the Radio Shack and give them instructions.
I'll post what I find out as soon as I can make the call.
The other retailer that Sirius said I can go to for help is Best Buy. I happened to be near one last night.
I went into Best Buy, told them I did not buy the item from Best Buy, and therefore I had no receipt. They looked around in their computer, returned the item for the current price at Best Buy, and then gave me that amount on a Best Buy gift card. They said this was because they felt bad because Sirius seemed to be giving me the run-around. Then they sent me to a neighboring Best Buy to pick up a new one with my new gift card, since the SIR-GM1 was not in stock at the Best Buy I was in. Apparently, they are a discontinued inventory item.
Anyhow, long story short, I now have a new SIR-GM1, sold to me from Best Buy. And the store I bought this one from has two more in stock, and told me if I have issues with this one, bring it back to them and not to bother calling Sirius for the Tech Support. They wanted to help me and now I will be a return Best Buy customer.
What great people I worked with. Danielle in Olympia WA Best Buy Customer Service went above and beyond to turn my problem into a positive experience.
I'll install the new unit this weekend and report back how well it works.
HOLY CRAP, that is a rarity in this day that they would go that far to make a new customer. Glad you had a good experience there.
There's an emoticon on here, the one that holds a certain flag, but I cannot seem to find it... :drool:
    • HM oils and cleaning. Well, soft deposits yes, perhaps. Like you say esters are present in in theory that should be a plus. But, is there enough? 🤔 The marker is the "Aniline Point" and it has to be pretty low to solve out baked on deposits. The softer sludge, yea, they do that and that is the claim. Valvoline R&P is the only HM oil I know of (Jury is out on Mobil 1's product) whose chemistry is uniquely able to remove the hard stuff and not be so aggressive as to swell seals to uselessness.    Oxidation levels in virgin oils blends is a good indicator of ester level and higher is generally a lower Aniline number and at one time we could predict without the $400 aniline test it's effectiveness. AN's, alkylated naphthalene doesn't show up in the oxidation test but does show in the aniline test and has become sort of a cheaper go to but most oils only add enough to solve the additive package. Not nearly enough to clean the harder carbon materials.   To your second question about does it matter. Yes is the short answer. Deposits are insulative. Those under the piston crown for example add octane requirement for knock free running. We don't' normally notice in todays motors due to Knock sensor driven ignition R-e-t-a-r-d. At least until the full slate of available values is consumed. Newer motors also often use oil jets to cool the piston to achieve tunes that would otherwise not be possible. Deposits on either side subtract from that. Deposits in fine screens used in VVT/VVL or DFM/AFM services live and die on cleanliness and screens are front and center. Vacuum pumps as well like brake booster in the K2's.    90% of todays oils are Group II+/III blends. A few more at PAO/AN/Group II's. A few boutique oils not Walmart shelf materials have enough solvency to prevent but not remove the hard stuff. R & P the current exception. Even HPL's EC30/40 used as directed (20% max) will get the soft stuff and some varnish out but not the hard stuff.    That orange varnish isn't baked on oil. Those are fuel varnishes left when the fuel diluted in the oil drops out when the oil cools. Like sugar does in a saturated mix of sugar and water that is put into the frig. That is ring sticking material and a glue the binds hard carbon sometimes.    Name brand shelf oils are intended to provide a useful service life at the least cost and highest benefit to the OEM who is trying very hard to keep you in $500 a month payment programs where the real money is made.   Did I miss anything you asked or left unsatisfied?
    • Yes, I understand. And I was saying (poorly), that it popped up on the DIC when I didn't have that info screen up. Just like you, but for a different maintenance issue. And just like yours mine didn't need to be shown at that time.
    • Ugh, amateurs.   But I did learn HM seal conditioners are esters.   I'm curious about deposit removal - some of the HM oils claim they really clean stuff up, the old and hard to reach stuff, and that's great? To Grumpy's point, a good oil should already be keeping the house pretty clean. I assume there are hard to reach places (underside of pistons?) and things that just accumulate baked-on oil and combustion vapors. If the deposits aren't friction or combustion surfaces and the deposit is just normal "seasoning", is it actually important to remove it?
    • You ask. The answer is yes. I think the strategy is brilliant. Or do you like more death and destruction? Gas is going down here. Maybe you need to change who you elect. Quit with the ridiculous statements or questions. You won’t get these answers.
    • Kicking off the weekend with $5.06 at the Kroger for 87. Are we great, yet?
