Trailer Lighting Problem
I have a 03 Silverado 1500 with a trailer lighting problem I'm hoping someone might know what I could try. The old 7-way trailer adaptor was corroded so I replaced it and tested the lights. I then found corrosion in the factory adaptor near the spare tire. I eliminated this adaptor and hardwired everything. I went to test the lights, everything works accept:
The drivers side brake light doesn't come on.
When the brakes are applied and I turn the passenger blinker on the driver side blink also for about 15 seconds, then it comes on constant like it should since the brakes are applied. If I then turn the passenger side blinker off both brake lights continue to work. If I stop applying the brakes or turn on the drivers side blinker and then turn it off the drivers side brake light stops working.
Everything else is working properly. I've tried finding a better ground with the same results.
Thanks for the help!
Sounds like wiring issues on the trailer. Might have to do some checking for broken and exposed wires on the trailer.
I'd take a meter and test all the pins on the plug on the truck. If they all work okay, then there is something up with the trailer wiring as Darcy mentioned.
IIRC the wiring should be:
white- ground
yellow- left/brake
green -right/brake
brown -tail
light green - backup
blue -trailer brakes
red - 12 volt +
light blue -Stop Lights * DO NOT USE*
This is for an '04. I know that GM changed it up from the '03 to '04 models. I had a light blue wire, for stoplights. I did not use it, but the stop lights work fine getting juice from the yellow and green wires.
I've been testing everything with a test light, I haven't even tried hooking it up to a trailer yet, so I know it is a problem with the truck. I also tried grounding when testing directly on the negative terminal of the battery with the same results. Are there other grounds in the circuit that I could check, if so, where are they located? Also, are there any relays or other things in the circuit that could go bad?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
