E3 Spark Plugs On An 8.1l
So i decided to continue my 100K mile maintenance on the truck today. I've already done fliuds (except the Trans). Got to the Plugs and wires today. I brought thundervolt 50 10.4mm and E3 spark plugs. The wires are beast by the way. The install with off with no problems. As soon as i started the truck up and was shaking hard :lol: . I read in another forum that the E3's would do that so i didn't think much of it. I drove about a hundred feet and the service engine light started to flash. Immeditaetly i'm thinking miss fire, i didn't get a good connection on one of the wires. checked everything and everything was good and tight. I didn't have any loss of power, the truck drove the same except it vibrated at idle and the light kept flashing. I took the truck over to a buddy who was tuning it for me and we did some data logging. He said that the knock was through the roof and was sure it was the spark plugs. I went ahead and got some OEM AC Delco Plats and installed them. Problem solved. Almost $100 bucks gone :D but the truck is running smooth. Oh yeah when i pulled the plug out of cylinder three and was black, smelled like gas, and the porcelin had seperated from the socket face. The old plugs were covered in ash and corroded really bad. My buddy who knows a thing or two about GM engines couldn't figure out how my truck was about to get a spark in the first place.
Moral of the story, the Big Block does not like E3 spark plugs :smoker: .
Hulk :lol:
I experienced shake at idle with those E-3 plugs and decided to take them out and stick with AC delco as well. Problem solved after taking the E3 plugs out. I heard that the design of the plug could pose a hazard to the engine if one of the metal endings got hot and broke off. I did however at first after putting in the E3 plugs like the truck had a little more pep to it, but it didn't take long before I felt a vibration at idle and that got me concerned. I did read good reviews about people using them in lawn mower engines, unfortunately those plugs won't fit any of my small engines.
I tried a few different plugs in my 8.1.
I played musical plugs in many combinations with tune, CAI, exhaust, etc...nothing worked as good as the original AC Delco part # plugs
OEM plugs often work the best. I was cautioned never to use Bosch plugs in my Mazda, so I use the OEM Denso plugs, engine still idles glass smooth with 226k miles on the clock. Of course, I replace the plug wires periodically too.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 646 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
