Rims For 1997 Chev 2500 2wd
The rim offset for 1997 Chev 2500 2WD (16 inch 6-bolt 6.5 inch width) is different from standard steel 4x4 rims (larger rim width). I have been looking for a couple of extra rims (to have a set of studded winter snow tires). The standard oem 2WD rims are scarce and nearly impossible to find in my area. (I have checked all local wreckers.) Tires are LT225/75R16 LRD. What is the impact of mounting winter tires on 4x4 rims for the back of the 2WD pickup? Would the different offset from the fronts affect handling or suspension of the truck?This is not a problem or issue for newer trucks as the rim offsets were standardized for 2wd and 4x4 models a few years later.
running a wheel with different offset than OE usuall affects bearing wear in the hubs and if you have the non full floater rear axle the axle will break much easier.
Thanks for the reply and comments ... maybe I will just hold off and keep watching around for the oe rims somewhere ... I don't want to put any unnecessary stress on any part of this truck....
Also depending on the amount of offset one is talking about and whether it is +ve or -ve from the OE value. A small amount of offset decrease from stock offset would not add any significant stress to the bearings or axle.
Thanks.... using the 4x4 rims instead of the 2wd rims would offset the tires towards the frame of the truck (inwards... ) by about 1 to 1.5 inches (I am guessing here by just looking at the rims)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
