Brake Light
Hummm... That a very interesting problem, especially since it continues to stay lit with the ignition off!
It sounds to me like an electronic problem. Electronic "chips" and circuit boards sometimes have similar problems.
BUT sometimes it can be something simple. Check your brake fluid and the wiring to your brake components under the hood.
Then there is the "crawling insect" shorting wires on a circuit board problem, so might look at the associated circuit boards for bugs or whatever should not be there. (Spilled liquids can cause this type of thing.)
Then if all else fails, get the wiring diagram, a multimeter, and start checking wires to be sure all the wiring is ok. Then if all the input wires are doing as they should, then that would leave an electronic circuit board problem as the prime suspect.
what side of vehicle is electronic circuit board, is it in the left kick panel by parking brake.
These are all around the vehicle in various metal or plastic "boxes" and used for different things.
Basically if something is "electronic" there is an electronic circuit board. Around the house, things like stereos, microwave, phones, etc. and lately just about anything which has a "digital" display has an electronic circuit board. So for newer appliances, include range, coffee maker, and refrigerator.
Same with a vehicle. The dash instrument cluster may have an electronic circuit board, the engine has a computer which is on an electronic circuit board, stereo, anti-lock brakes, information center, mirror with compass, climate control, and on and on. Then these things can be connected together to "talk" to each other.
To find brake related electronic circuit boards (electronics), you would look at a factory service manual and wiring diagram which would explain how something like the brake light operates, which inputs and electronic modules control it, associated wiring, cables, wire colors, locations, and troubleshooting with a multimeter and pinpoint tests of specific locations on various connectors.
Thanks for your Help. Looks like fun.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
