Avic F700bt Pioneer Nav Unit
Well i took the plunge this weekend and ordered one of these untis up, currently only going to change out the head unit and maybe get a sub and amp for the first phase. Just do not have the money to replace everything atm so looking to get the most bang for my buck.
Im not the best at stereo stuff so i think im going to have this professionally done, my question is what should i expect to pay to get the head unit swapped and working with the current bose speakers. I know i will need a adapter "which one by the way, looks like there are two different kinds" and a thing for the steering controls if i want them to work also? I just dont want to get ripped off, i have heard installs ranging from 60 bucks to over 200 for just the head unit install labor.
Also does anyone run a single downfire sub in any of these ext cab trucks, looking at maybe a box from subthump, as the JL stealth boxes are just crazy over priced for what you get.
i just picked up a box and sub from ebay. the seller was rodney74. he gave me the sigle 10 downfire box and an idq10v.3 sub for 250 shipped. the sub is more of a sq sub but it's made from 3/4 mdf and looks pretty solid.
Wow is all i can say, this head unit is freakin amazing imo. Ipod setup works good, nav is very easy to read and understand, and it looks like a factory unit once the shop trimmed the back plate to allow a flush fit. Also bluetooth works great pairing right up to my krave phone. Not bad for under 400 bucks not to mention it even sounds decent with the factory bose speakers.
I think a lot of the reviews you see on the web that hate all it's quirks are either perfectionist or just hate pioneer because i cant see any downs to this unit for it's cost. If your looking for a great ipod playing nav displaying radio i would give this one a look.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
