Nascar Truck series
RyanbabZ71
Anyone going to
08/18/01
Sears Craftsman 175 / Chicago Motor Speedway
ESPN
MRN
5 p.m.
4:30 p.m.
Also where can i buy tickets online?
Do a search for the racetrack. You can usually get tix from their website.
THANKS
Also ticketmaster.com has em
